跳转到主内容
Toshiba Portege M300 LCD Replacement
你所需要的
  1. Toshiba Portege M300 LCD Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer over onto its back.
  2. Toshiba Portege M300 LCD Replacement: 步骤 2 中的图像 1,2 Toshiba Portege M300 LCD Replacement: 步骤 2 中的图像 2,2
    • Slide the lock on the left side to the unlock position.
    • Slide the lock on the right side to the unlock position until there is a clicking sound.
  3. Toshiba Portege M300 LCD Replacement: 步骤 3 中的图像 1,2 Toshiba Portege M300 LCD Replacement: 步骤 3 中的图像 2,2
    • Remove the battery by sliding it away from the laptop.
    • Make sure the two locks from the previous step are in the unlocked position while sliding the battery away.
  4. Toshiba Portege M300 LCD Replacement, LCD: 步骤 4 中的图像 1,2 Toshiba Portege M300 LCD Replacement, LCD: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to unsnap the right hand side speaker cover.
  5. Toshiba Portege M300 LCD Replacement: 步骤 5 中的图像 1,2 Toshiba Portege M300 LCD Replacement: 步骤 5 中的图像 2,2
    • Remove the rest of the cover by sliding it to the right and lifting the right edge.
  6. Toshiba Portege M300 LCD Replacement: 步骤 6 中的图像 1,2 Toshiba Portege M300 LCD Replacement: 步骤 6 中的图像 2,2
    • Remove all eight plastic circular covers on the plastic screen bezel.
    • Only seven of these plastic covers will contain screws underneath.
    • Unscrew all seven screws with a Phillips head #000 screwdriver.
  7. Toshiba Portege M300 LCD Replacement: 步骤 7 中的图像 1,2 Toshiba Portege M300 LCD Replacement: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to separate the screen bezel from the rest of the case.
    • Pull at the top edge of the LCD to separate it from the top part of the case.
    • Only separate the casing and the LCD by an inch—there are still wires connecting them.
  8. Toshiba Portege M300 LCD Replacement: 步骤 8 中的图像 1,2 Toshiba Portege M300 LCD Replacement: 步骤 8 中的图像 2,2
    • Use a Phillips #000 to unscrew the one 2.8 mm fine thread screw holding the wire connected to the right face of the LCD.
  9. Toshiba Portege M300 LCD Replacement: 步骤 9 中的图像 1,1
    • Flip the LCD over onto the back.
    • Gently pull the connection on the corner of the LCD to disconnect.
  10. Toshiba Portege M300 LCD Replacement: 步骤 10 中的图像 1,2 Toshiba Portege M300 LCD Replacement: 步骤 10 中的图像 2,2
    • Remove the tape connecting LCD to the inverter.
    • Use tweezers to remove the LCD cable from the inverter.
结论
另外一个人完成了本指南。
Alison Wendt
于04/18/13注册
135 声望
创作了6篇指南
团队
Cal Poly, Team 21-51, Johann Spring 2013 Cal Poly, Team 21-51, Johann Spring 2013 的会员
CPSU-JOHANN-S13S21G51
3 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 993
