跳转到主内容
Toshiba Portege 3110CT Fan Replacement
你所需要的
  1. Toshiba Portege 3110CT Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Begin by removing the battery and flipping the laptop over to see the screws
    • Using a phillips head screwdriver to remove the screws that secure the back
  2. Toshiba Portege 3110CT Fan Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop back over and open it up carefully
    • Lift up the bottom panel where the mouse click buttons are
    • Lift up slowly as simply flip it up and rest it on the keyboard as not to damage the ribbon cable connecting it
    • Using the spudger disconnect the ribbon cable connected to the bottom of the panel
  3. Toshiba Portege 3110CT Fan Replacement: 步骤 3 中的图像 1,1
    • Using the same size phillips as before remove the two screws that hold the keyboard in place
    • Then simply lift the keyboard up and slide it down and out
  4. Toshiba Portege 3110CT Fan Replacement: 步骤 4 中的图像 1,1
    • Remove this final screw and lift out the fan
结论
Spencer Gamble
于10/20/16注册
401 声望
创作了4篇指南
团队
UMass Dartmouth, Team 6-4, Martin Fall 2016 UMass Dartmouth, Team 6-4, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S6G4
3 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 11
总计 283
