跳转到主内容
加入维修社区 - 创建账户
Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement
你所需要的
  1. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement, DVD Drive: 步骤 1 中的图像 1,2 Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement, DVD Drive: 步骤 1 中的图像 2,2
    • Turn the DVD player upside down.
    • Slide the lock switch to the side.
    • Slide the battery pack toward the lock switch and off of the back case.
  2. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the following twelve screws:
    • Ten 7 mm Phillips #00 screws
    • Two 8 mm Phillips #00 screws
  3. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 3 中的图像 1,1
    • Use your fingers to pull the back case away from the body of the DVD player.
    • Remove the back case.
  4. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 4 中的图像 1,1
    • Use your fingers to pull off the plastic sheet.
  5. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the following screw:
    • One 2 mm Phillips #00 screw
    • Detach the gray wire.
  6. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 6 中的图像 1,1
    • Disconnect the ribbon cable by pulling it straight out of the connector.
  7. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the following five screws:
    • Three 4 mm Phillips #00 screws
    • Two 2 mm Phillips #00 screws
  8. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 8 中的图像 1,1
    • Remove three rubber stoppers.
  9. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 9 中的图像 1,1
    • Remove the following screws:
    • Two 4mm Phillips #00 screws
  10. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 10 中的图像 1,1
    • Use your fingers to pry the motherboard away from the upper case so you can access the DVD drive wires.
  11. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 11 中的图像 1,1
    • Flip the DVD player over to access the drive wires.
    • Pull the bundled cable away from the connector in the same direction the individual wires are running.
  12. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: 步骤 12 中的图像 1,1
    • Remove all of the DVD drive components from the case.
结论
Katarina Howald
于03/18/20注册
205 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 24
总计 592
