跳转到主内容
Toshiba NB305 Keyboard Replacement
你所需要的
  1. Toshiba NB305 Keyboard  Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the laptop upside down with the battery facing you.
  2. Toshiba NB305 Keyboard  Replacement: 步骤 2 中的图像 1,1
    • Use your right hand to move latch 1 to the right to unlock the battery.
  3. Toshiba NB305 Keyboard  Replacement: 步骤 3 中的图像 1,2 Toshiba NB305 Keyboard  Replacement: 步骤 3 中的图像 2,2
    • Use your left hand to hold latch 2 to the left.
    • Simultaneously take the battery out with your right hand.
  4. Toshiba NB305 Keyboard  Replacement, Keyboard: 步骤 4 中的图像 1,2 Toshiba NB305 Keyboard  Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Remove the four F4 screws and the F6 screw underneath battery.
    • 4mm Phillips-0 screws.
    • 6mm Phillips-0 screws.
  5. Toshiba NB305 Keyboard  Replacement: 步骤 5 中的图像 1,3 Toshiba NB305 Keyboard  Replacement: 步骤 5 中的图像 2,3 Toshiba NB305 Keyboard  Replacement: 步骤 5 中的图像 3,3
    • Using a spudger, gently pry out on the plastic cover.
    • Turn it over and remove plastic cover on top of laptop with power button on it.
  6. Toshiba NB305 Keyboard  Replacement: 步骤 6 中的图像 1,2 Toshiba NB305 Keyboard  Replacement: 步骤 6 中的图像 2,2
    • Use the plastic opening tool in little notches above the keyboard
    • Gently pry up on the keyboard until it lifts up.
    • You might hear a click when the keyboard releases.
  7. Toshiba NB305 Keyboard  Replacement: 步骤 7 中的图像 1,1
    • Gently lift the keyboard up toward the screen.
    • Be careful! There is a cable still connected from the computer to the keyboard.
  8. Toshiba NB305 Keyboard  Replacement: 步骤 8 中的图像 1,2 Toshiba NB305 Keyboard  Replacement: 步骤 8 中的图像 2,2
    • The ribbon cable has a clip on each side holding it to the motherboard.
    • Using a spudger, press on the clips to release the cable.
    • The cable will slide out on its own when it is properly released.
结论
另外一个人完成了本指南。
Nuri Chung
于10/25/16注册
368 声望
创作了3篇指南
团队
USF Tampa, Team 5-5, Lacy Fall 2016 USF Tampa, Team 5-5, Lacy Fall 2016 的会员
USFT-LACY-F16S5G5
3 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 695
