跳转到主内容
Toshiba NB205 N330PK RAM Replacement
你所需要的
  1. Toshiba NB205 N330PK RAM Replacement, RAM: 步骤 1 中的图像 1,2 Toshiba NB205 N330PK RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Use a bit driver and a Phillips #0 bit to remove the one 5 mm retaining screw.
    • Lift the panel up and out of the way.
  2. Toshiba NB205 N330PK RAM Replacement: 步骤 2 中的图像 1,3 Toshiba NB205 N330PK RAM Replacement: 步骤 2 中的图像 2,3 Toshiba NB205 N330PK RAM Replacement: 步骤 2 中的图像 3,3
    • The RAM chip is secured by two retaining arms that run parallel with the chip. Gently pull these arms in opposite directions off of the chip.
    • After the retainer arms are free, push the chip towards the top of the netbook. This will free the chip for removal.
  3. Toshiba NB205 N330PK RAM Replacement: 步骤 3 中的图像 1,2 Toshiba NB205 N330PK RAM Replacement: 步骤 3 中的图像 2,2
    • Push the replacement RAM into the original position.
    • Reattach both securing arms onto the sides of the RAM chip.
  4. Toshiba NB205 N330PK RAM Replacement: 步骤 4 中的图像 1,2 Toshiba NB205 N330PK RAM Replacement: 步骤 4 中的图像 2,2
    • Place the panel back into the securing slots and let it rest in its original position.
    • With the bit driver and Phillips #0 bit, secure the panel down with one screw.
结论
另外一个人完成了本指南。
Mason McCaskill
于10/18/13注册
1,021 声望
创作了9篇指南
团队
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G2
3 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 524
