跳转到主内容
Toshiba NB205 N330PK Keyboard Replacement
你所需要的
  1. Toshiba NB205 N330PK Keyboard Replacement, Power Button: 步骤 1 中的图像 1,2 Toshiba NB205 N330PK Keyboard Replacement, Power Button: 步骤 1 中的图像 2,2
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Toshiba NB205 N330PK Keyboard Replacement: 步骤 2 中的图像 1,2 Toshiba NB205 N330PK Keyboard Replacement: 步骤 2 中的图像 2,2
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
  3. Toshiba NB205 N330PK Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba NB205 N330PK Keyboard Replacement: 步骤 3 中的图像 2,2
    • While holding the top of the netbook, flip the netbook over.
  4. Toshiba NB205 N330PK Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba NB205 N330PK Keyboard Replacement: 步骤 4 中的图像 2,2
    • Carefully lift off the power bar assembly for access to the button and receiver.
  5. Toshiba NB205 N330PK Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,2 Toshiba NB205 N330PK Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
  6. Toshiba NB205 N330PK Keyboard Replacement: 步骤 6 中的图像 1,2 Toshiba NB205 N330PK Keyboard Replacement: 步骤 6 中的图像 2,2
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the broken keyboard off.
  7. Toshiba NB205 N330PK Keyboard Replacement: 步骤 7 中的图像 1,3 Toshiba NB205 N330PK Keyboard Replacement: 步骤 7 中的图像 2,3 Toshiba NB205 N330PK Keyboard Replacement: 步骤 7 中的图像 3,3
    • Reattach the new electrical connection into the old connection location.
    • Place the keyboard into the original location starting with the bottom first.
    • Gently press the keyboard down to secure it into its original location.
终点
另外一个人完成了本指南。
Mason McCaskill
于10/18/13注册
1,000 声望
创作了9篇指南
团队
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G2
3 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 834
