当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Using the spudger, gently pry the desired key up on one side. This will release the key.
The key is held in place by very small plastic pieces. Improper removal or installation may damage key permanently and require entire keyboard replacement.
Use a brush to remove debris and use a cleaner cloth to remove residue.
Similarly, remove debris and residue from the area of the keyboard where the key was originally seated.
Once clean, set the key above its original position and firmly press it back into place.
If cleaned and installed properly the key should depress smoothly and spring back to normal position once released.
取消:我没有完成这个指南。
与4其他贡献者
于10/18/13注册
1,000 声望
创作了9篇指南
徽章: 10
+ 7更多徽章
CLEM-BENSON-F13S14G2
3 名成员
创作了27篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 486
