跳转到主内容
Toshiba NB205 N330PK Battery Replacement
你所需要的
  1. Toshiba NB205 N330PK Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • To release the battery, first slide the switch to the right.
  2. Toshiba NB205 N330PK Battery Replacement: 步骤 2 中的图像 1,1
    • Use your right hand to slide the second release switch to the right to unlock the battery.
    • Simultaneously, use your left hand to pull the battery towards the top of the netbook.
  3. Toshiba NB205 N330PK Battery Replacement: 步骤 3 中的图像 1,2 Toshiba NB205 N330PK Battery Replacement: 步骤 3 中的图像 2,2
    • With a soft or medium bristle brush, gently remove debris from the battery's contacts.
    • Similarly, remove debris from the matching contacts on the netbook itself.
    • Ensure hands and brush are dry to prevent personal injury from electric shock.
  4. Toshiba NB205 N330PK Battery Replacement: 步骤 4 中的图像 1,2 Toshiba NB205 N330PK Battery Replacement: 步骤 4 中的图像 2,2
    • To reconnect the battery, align these hooks with the designated holes on the netbook.
    • Firmly press the battery back into its original position. A clicking noise should be heard as the switch (bottom switch in photo's orientation) automatically moves.
  5. Toshiba NB205 N330PK Battery Replacement: 步骤 5 中的图像 1,1
    • Move the switch to the left position to secure the battery and lock it in place. This ensure a strong battery connection and prevents battery from falling out.
结论
Follow this guide from beginning to end for battery removal, replacement, and cleaning.
另外一个人完成了本指南。
Mason McCaskill
于10/18/13注册
1,000 声望
创作了9篇指南
团队
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G2
3 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 812
