你所需要的
Unscrew all screws from the bottom and unplug the battery.
Flip the laptop over and by using a prying tool, carefully remove the basel above the keyboard.
Remove the 2 screws that hold the keyboard, lift it up, unplug it and set it aside.
Carefully unplug the cables and remove the screws that hold the panel in place.
Remove the display.
Lift up the panel and replace the thermal pads. Make sure they are the correct thickness..
You can also disconnect the fan and clean it too.
另外一个人完成了本指南。
