跳转到主内容
简介
Hello, in this simple guide I’ll be showing you how to replace the keyboard of Toshiba NB100 laptop.
配件
没有特定配件。
  1. Remove the 3 screws holding the panel above the keyboard. The third one should be below the battery, so remove it as well Use a spudger to pop the panel and remove it.
    • Remove the 3 screws holding the panel above the keyboard. The third one should be below the battery, so remove it as well
    • Use a spudger to pop the panel and remove it.
  2. Remove the 2 screws holding the keyboard in place. Carefully lift the keyboard and gently disconnect the cable.
    • Remove the 2 screws holding the keyboard in place.
    • Carefully lift the keyboard and gently disconnect the cable.
    • Thats it. Remove the old keyboard and replace it with the new one.
结论
另外一个人完成了本指南。
Simeon Brankov
于2020年11月08日注册
3,157 信誉积分
创作了31篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 5
总计 45
