跳转到主内容
Toshiba Mini NB505 Keyboard Replacement
你所需要的
  1. Toshiba Mini NB505 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Located on the bottom of the laptop, find the two tabs shown in the picture and push both of them outwards away from the battery.
  2. Toshiba Mini NB505 Keyboard Replacement: 步骤 2 中的图像 1,1
    • While pushing the tabs outwards, push on the raised bumps on the battery away from the laptop.
  3. Toshiba Mini NB505 Keyboard Replacement: 步骤 3 中的图像 1,1
    • The battery is now removed
  4. Toshiba Mini NB505 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Locate the five 1.2 mm Phillips # 000 screws inside of the battery housing.
  5. Toshiba Mini NB505 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips head #000 screwdriver, carefully remove the five 1.2mm screws.
  6. Toshiba Mini NB505 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Use a plastic pry tool to pop the tab holding the keyboard to the laptop.
  7. Toshiba Mini NB505 Keyboard Replacement: 步骤 7 中的图像 1,2 Toshiba Mini NB505 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Remove plastic plate above keyboard.
  8. Toshiba Mini NB505 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Lift the keyboard gently away from the computer.
    • Do not attempt to fully remove the keyboard, as it is attached to the laptop by a ribbon cable.
  9. Toshiba Mini NB505 Keyboard Replacement: 步骤 9 中的图像 1,3 Toshiba Mini NB505 Keyboard Replacement: 步骤 9 中的图像 2,3 Toshiba Mini NB505 Keyboard Replacement: 步骤 9 中的图像 3,3
    • Locate the ribbon wire under the keyboard. Slide the white tabs forward and the keyboard will come loose.
结论
3等其他人完成本指南。
Owen Velho
于03/09/16注册
508 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-7, Catania Spring 2016 UMass Dartmouth, Team 7-7, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S7G7
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 1,418
