跳转到主内容
Toshiba L15W-B1303 Battery Replacement
你所需要的
  1. Toshiba L15W-B1303 Battery Replacement, Bottom Panel: 步骤 1 中的图像 1,3 Toshiba L15W-B1303 Battery Replacement, Bottom Panel: 步骤 1 中的图像 2,3 Toshiba L15W-B1303 Battery Replacement, Bottom Panel: 步骤 1 中的图像 3,3
    • Turn the laptop over and place it on its top side.
    • Remove ten 10mm JIS #00 screws from the bottom panel of the laptop.
    • Using the iFixit opening tool, remove the bottom panel of the laptop.
  2. Toshiba L15W-B1303 Battery Replacement, Battery: 步骤 2 中的图像 1,3 Toshiba L15W-B1303 Battery Replacement, Battery: 步骤 2 中的图像 2,3 Toshiba L15W-B1303 Battery Replacement, Battery: 步骤 2 中的图像 3,3
    • Lift the battery and remove it from the laptop.
    • The battery's cable connector is still attached to the laptop, so lift the battery out carefully.
    • Disconnect the battery carefully from the port by detaching the connector with a plastic opening tool or a spudger.
结论
Peyton Campbell
于01/22/20注册
145 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 397
