跳转到主内容
Toshiba HD-A2 Optical Lens Replacement
你所需要的
  1. Toshiba HD-A2 Optical Lens Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Optical Lens Replacement: 步骤 2 中的图像 1,2 Toshiba HD-A2 Optical Lens Replacement: 步骤 2 中的图像 2,2
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Optical Lens Replacement: 步骤 3 中的图像 1,1
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Optical Lens Replacement, Optical Drive: 步骤 4 中的图像 1,3 Toshiba HD-A2 Optical Lens Replacement, Optical Drive: 步骤 4 中的图像 2,3 Toshiba HD-A2 Optical Lens Replacement, Optical Drive: 步骤 4 中的图像 3,3
    • Remove five 6mm Phillips screws with a Phillips #2 screwdriver.
    • The 2 screws on the right of the cartridge are better shown in the second and third photos.
  5. Toshiba HD-A2 Optical Lens Replacement: 步骤 5 中的图像 1,2 Toshiba HD-A2 Optical Lens Replacement: 步骤 5 中的图像 2,2
    • Remove the remaining four 6mm Phillips screws.
  6. Toshiba HD-A2 Optical Lens Replacement: 步骤 6 中的图像 1,3 Toshiba HD-A2 Optical Lens Replacement: 步骤 6 中的图像 2,3 Toshiba HD-A2 Optical Lens Replacement: 步骤 6 中的图像 3,3
    • Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
  7. Toshiba HD-A2 Optical Lens Replacement: 步骤 7 中的图像 1,2 Toshiba HD-A2 Optical Lens Replacement: 步骤 7 中的图像 2,2
    • Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
  8. Toshiba HD-A2 Optical Lens Replacement: 步骤 8 中的图像 1,1
    • Using your fingers, gently pull off the wires.
  9. Toshiba HD-A2 Optical Lens Replacement: 步骤 9 中的图像 1,2 Toshiba HD-A2 Optical Lens Replacement: 步骤 9 中的图像 2,2
    • Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
    • Be careful not to rip the tape attaching the green circuit boards together.
  10. Toshiba HD-A2 Optical Lens Replacement: 步骤 10 中的图像 1,2 Toshiba HD-A2 Optical Lens Replacement: 步骤 10 中的图像 2,2
    • Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
  11. Toshiba HD-A2 Optical Lens Replacement: 步骤 11 中的图像 1,2 Toshiba HD-A2 Optical Lens Replacement: 步骤 11 中的图像 2,2
    • Using your hands, gently lift the lid and carefully place it aside.
  12. Toshiba HD-A2 Optical Lens Replacement: 步骤 12 中的图像 1,3 Toshiba HD-A2 Optical Lens Replacement: 步骤 12 中的图像 2,3 Toshiba HD-A2 Optical Lens Replacement: 步骤 12 中的图像 3,3
    • Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
  13. Toshiba HD-A2 Optical Lens Replacement, Optical Lens: 步骤 13 中的图像 1,1
    • The optical lens will be resting aside the small green circuit board.
  14. Toshiba HD-A2 Optical Lens Replacement: 步骤 14 中的图像 1,2 Toshiba HD-A2 Optical Lens Replacement: 步骤 14 中的图像 2,2
    • Using a prying tool, wedge the edge of the tool underneath the end of the optical lens closest to the green circuit board. Gently push down to pop off the optical lens.
结论
Nouriyah Saleh
于10/22/18注册
800 声望
创作了6篇指南
团队
UC Davis, Team S11-G1, Lore Fall 2018 UC Davis, Team S11-G1, Lore Fall 2018 的会员
UCD-LORE-F18S11G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 547
