跳转到主内容
Toshiba HD-A2 Drive Belt Replacement
你所需要的
  1. Toshiba HD-A2 Drive Belt Replacement, Top Panel: 步骤 1 中的图像 1,1
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Drive Belt Replacement: 步骤 2 中的图像 1,2 Toshiba HD-A2 Drive Belt Replacement: 步骤 2 中的图像 2,2
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Drive Belt Replacement: 步骤 3 中的图像 1,1
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Drive Belt Replacement, Optical Drive: 步骤 4 中的图像 1,3 Toshiba HD-A2 Drive Belt Replacement, Optical Drive: 步骤 4 中的图像 2,3 Toshiba HD-A2 Drive Belt Replacement, Optical Drive: 步骤 4 中的图像 3,3
    • Remove five 6mm Phillips screws with a Phillips #2 screwdriver.
    • The 2 screws on the right of the cartridge are better shown in the second and third photos.
  5. Toshiba HD-A2 Drive Belt Replacement: 步骤 5 中的图像 1,2 Toshiba HD-A2 Drive Belt Replacement: 步骤 5 中的图像 2,2
    • Remove the remaining four 6mm Phillips screws.
  6. Toshiba HD-A2 Drive Belt Replacement: 步骤 6 中的图像 1,3 Toshiba HD-A2 Drive Belt Replacement: 步骤 6 中的图像 2,3 Toshiba HD-A2 Drive Belt Replacement: 步骤 6 中的图像 3,3
    • Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
  7. Toshiba HD-A2 Drive Belt Replacement: 步骤 7 中的图像 1,2 Toshiba HD-A2 Drive Belt Replacement: 步骤 7 中的图像 2,2
    • Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
  8. Toshiba HD-A2 Drive Belt Replacement: 步骤 8 中的图像 1,1
    • Using your fingers, gently pull off the wires.
  9. Toshiba HD-A2 Drive Belt Replacement: 步骤 9 中的图像 1,2 Toshiba HD-A2 Drive Belt Replacement: 步骤 9 中的图像 2,2
    • Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
    • Be careful not to rip the tape attaching the green circuit boards together.
  10. Toshiba HD-A2 Drive Belt Replacement: 步骤 10 中的图像 1,2 Toshiba HD-A2 Drive Belt Replacement: 步骤 10 中的图像 2,2
    • Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
  11. Toshiba HD-A2 Drive Belt Replacement: 步骤 11 中的图像 1,2 Toshiba HD-A2 Drive Belt Replacement: 步骤 11 中的图像 2,2
    • Using your hands, gently lift the lid and carefully place it aside.
  12. Toshiba HD-A2 Drive Belt Replacement: 步骤 12 中的图像 1,3 Toshiba HD-A2 Drive Belt Replacement: 步骤 12 中的图像 2,3 Toshiba HD-A2 Drive Belt Replacement: 步骤 12 中的图像 3,3
    • Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
  13. Toshiba HD-A2 Drive Belt Replacement, Drive Belt: 步骤 13 中的图像 1,3 Toshiba HD-A2 Drive Belt Replacement, Drive Belt: 步骤 13 中的图像 2,3 Toshiba HD-A2 Drive Belt Replacement, Drive Belt: 步骤 13 中的图像 3,3
    • Slide out the disc tray. If it's stuck, turn the white gear to the right to release the tray.
  14. Toshiba HD-A2 Drive Belt Replacement: 步骤 14 中的图像 1,1
    • The drive belt is the black rubber band.
  15. Toshiba HD-A2 Drive Belt Replacement: 步骤 15 中的图像 1,2 Toshiba HD-A2 Drive Belt Replacement: 步骤 15 中的图像 2,2
    • Using your fingers, gently remove the drive belt.
    • If you have difficulty using your fingers, use a prying tool.
结论
Nouriyah Saleh
于10/22/18注册
800 声望
创作了6篇指南
团队
UC Davis, Team S11-G1, Lore Fall 2018 UC Davis, Team S11-G1, Lore Fall 2018 的会员
UCD-LORE-F18S11G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 400
