跳转到主内容
Toshiba Excite 7c Screen Replacement
你所需要的
  1. Toshiba Excite 7c Screen Replacement, Motherboard: 步骤 1 中的图像 1,2 Toshiba Excite 7c Screen Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Place an iFixit opening tool in the seam between the screen and back casing.
    • Apply pressure down all four sides to separate the back casing from the screen.
    • Place the tablet face down and carefully remove the back panel.
  2. Toshiba Excite 7c Screen Replacement: 步骤 2 中的图像 1,2 Toshiba Excite 7c Screen Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the five 6 mm screws from the motherboard.
    • Use tweezers to gently disconnect the two ribbon cables.
    • Pull straight up to remove the board.
  3. Toshiba Excite 7c Screen Replacement, Screen: 步骤 3 中的图像 1,1
    • With all of the components removed continue with reassembly using a new screen as the base for reassembly.
结论
另外一个人完成了本指南。
Reyna Serrato
于10/25/14注册
96 声望
创作了5篇指南
团队
Gateway, Team 1-2, Johnson Fall 2014 Gateway, Team 1-2, Johnson Fall 2014 的会员
GCC-JOHNSON-F14S1G2
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 350
