跳转到主内容
Toshiba Excite 7c Battery Replacement
你所需要的
  1. Toshiba Excite 7c Battery Replacement, Open  Device: 步骤 1 中的图像 1,2 Toshiba Excite 7c Battery Replacement, Open  Device: 步骤 1 中的图像 2,2
    • To open your device use the plastic opener. Locate the seam on your device and gently separate applying pressure down all four sides.
    • The back casing will start to peel away from the screen.
    • Carefully lift and remove the back panel with tablet lying face down on table. this will reveal the back side.
  2. Toshiba Excite 7c Battery Replacement, Remove Battery: 步骤 2 中的图像 1,3 Toshiba Excite 7c Battery Replacement, Remove Battery: 步骤 2 中的图像 2,3 Toshiba Excite 7c Battery Replacement, Remove Battery: 步骤 2 中的图像 3,3
    • Locate the battery on the back of your device.
    • Remove the battery connector using a pair of tweezers.
    • On the side of the battery peel back but do not remove the two black pieces of tape.
    • Remove just to the white line NOT completely.
    • Carefully lift the battery out of the device, and set aside.
结论
3等其他人完成本指南。
Reyna Serrato
于10/25/14注册
96 声望
创作了5篇指南
团队
Gateway, Team 1-2, Johnson Fall 2014 Gateway, Team 1-2, Johnson Fall 2014 的会员
GCC-JOHNSON-F14S1G2
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 665
