你所需要的
Remove the back cover.
Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
Remove any black tape from the device.
Keep the tape, you will need to put it back on when you are done.
Unscrew the battery from the device.
The device has 5 screws to remove, keep the screws.
Remove the the remaining 3 screws to unfasten circuit board. Keep the screws.
The screen is connected to the circuit board by 2 “Data Cables” (orange ribbons). Data cables include 3 working components, data cables, the white harness plug, and the black lever.
Gently flip the black lock up with an opening tool and unplug data cables.
Use an opening tool to remove the circuit board by gently coaxing it from the clips located just to the right of the circuit board.
Flip the circuit board over, the rear facing camera is the black rectangle in the upper right corner of the circuit board.
Gently unplug the camera from the circuit board and plug the new camera in.
