跳转到主内容
Toshiba Excite 7 Battery Removal
你所需要的
  1. Toshiba Excite 7 Battery Removal, Battery Removal: 步骤 1 中的图像 1,3 Toshiba Excite 7 Battery Removal, Battery Removal: 步骤 1 中的图像 2,3 Toshiba Excite 7 Battery Removal, Battery Removal: 步骤 1 中的图像 3,3
    • Remove the back cover.
    • Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
    • After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
  2. Toshiba Excite 7 Battery Removal, Remove Tape: 步骤 2 中的图像 1,2 Toshiba Excite 7 Battery Removal, Remove Tape: 步骤 2 中的图像 2,2
    • Remove any black tape from the device.
    • Keep the tape, you will need to put it back on when you are done.
  3. Toshiba Excite 7 Battery Removal, Unplug Wires: 步骤 3 中的图像 1,2 Toshiba Excite 7 Battery Removal, Unplug Wires: 步骤 3 中的图像 2,2
    • Unplug the wires from the battery.
    • The battery is the black rectangle in the middle of the device. The device has two wiring harnesses attached to it, one just above the battery and one just to the right.
  4. Toshiba Excite 7 Battery Removal, remove screws: 步骤 4 中的图像 1,2 Toshiba Excite 7 Battery Removal, remove screws: 步骤 4 中的图像 2,2
    • Unscrew the battery from the device.
    • The device has 5 screws to remove, keep the screws.
  5. Toshiba Excite 7 Battery Removal, Unclip and remove battery: 步骤 5 中的图像 1,2 Toshiba Excite 7 Battery Removal, Unclip and remove battery: 步骤 5 中的图像 2,2
    • The battery has one clip you will need to remove. The clip is located at the bottom right corner of the battery just above the right speaker. The speakers and wires are not secured to the battery, they may fall off.
    • Push the clip back then lift the battery up.
结论
4等其他人完成本指南。
osmel fermin
于01/15/15注册
176 声望
撰写一个指南
团队
USF Tampa, Team 1-3, Tanski Winter 2015 USF Tampa, Team 1-3, Tanski Winter 2015 的会员
USFT-TANSKI-W15S1G3
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,778
