跳转到主内容
Toshiba Equium M70 Faulty Graphics
你所需要的
  1. Toshiba Equium M70 Faulty Graphics, Toshiba Equium M70 Faulty Graphics: 步骤 1 中的图像 1,1
    • This is a complete top half strip down to fix (takes me less than 30 minutes)
  2. Toshiba Equium M70 Faulty Graphics: 步骤 2 中的图像 1,1
    • this is the culprit, as you can see the shim can easily overheat & go concave lifting off the chip.
  3. Toshiba Equium M70 Faulty Graphics: 步骤 3 中的图像 1,1
    • cut a thin piece of alloy to the same size as the existing shim, i used an old alloy door push plate(easy to cut) & is the ideal thickness
  4. Toshiba Equium M70 Faulty Graphics: 步骤 4 中的图像 1,1
    • Thoroughly clean the chip with pure alcohol, then apply an even spread of good quality thermal paste(Arctic silver 5) will never let you down
  5. Toshiba Equium M70 Faulty Graphics: 步骤 5 中的图像 1,1
    • THen apply more thermal paste to the top of the shim
  6. Toshiba Equium M70 Faulty Graphics: 步骤 6 中的图像 1,1
    • The new alloy shim is under the existing thin shim. I've done more than 20 of these repairs & had 100% success rate I always do the same to the CPU (might as well your already in there).,
  7. Toshiba Equium M70 Faulty Graphics: 步骤 7 中的图像 1,1
    • This is the CPU with the new alloy shim fitted.
结论
3等其他人完成本指南。
Terry Sim
于02/12/11注册
207 声望
撰写一个指南
一条评论
Pros: Very good hi-res pictures, well explained.
Cons: The disassembly instructions are missing
Nicola Nascimento - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 16
总计 2,049
