跳转到主内容
Toshiba Encore WT8-A Tablet Camera Replacement
你所需要的
  1. Toshiba Encore WT8-A Tablet  Camera Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the 4 – 4.5 mm screws from the motherboard assembly.
  2. Toshiba Encore WT8-A Tablet  Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the 2 – 3.5 mm screws from the motherboard assembly.
  3. Toshiba Encore WT8-A Tablet  Camera Replacement: 步骤 3 中的图像 1,1
    • The motherboard should come free at this point.
  4. Toshiba Encore WT8-A Tablet  Camera Replacement, Camera: 步骤 4 中的图像 1,1
    • Use small plastic opening tool for the following steps.
  5. Toshiba Encore WT8-A Tablet  Camera Replacement: 步骤 5 中的图像 1,2 Toshiba Encore WT8-A Tablet  Camera Replacement: 步骤 5 中的图像 2,2
    • Use small plastic opening tool to pry rear facing camera flat top connector from motherboard.
  6. Toshiba Encore WT8-A Tablet  Camera Replacement: 步骤 6 中的图像 1,1
    • The rear facing camera should come free at this point.
  7. Toshiba Encore WT8-A Tablet  Camera Replacement: 步骤 7 中的图像 1,1
    • Use small plastic opening tool to pry front facing camera flat top connector from the motherboard
  8. Toshiba Encore WT8-A Tablet  Camera Replacement: 步骤 8 中的图像 1,2 Toshiba Encore WT8-A Tablet  Camera Replacement: 步骤 8 中的图像 2,2
    • The front facing camera should come free at this point.
结论
Melanie Mestre
于09/20/16注册
116 声望
撰写一个指南
团队
USF Tampa, Team 17-4, Blackwell Fall 2016 USF Tampa, Team 17-4, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S17G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 692
