跳转到主内容
Toshiba Encore Mini Speakers Replacement
你所需要的
  1. Toshiba Encore Mini Speakers Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Encore Mini Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Speakers Replacement: 步骤 2 中的图像 1,1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Speakers Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Speakers Replacement: 步骤 4 中的图像 1,2 Toshiba Encore Mini Speakers Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Speakers Replacement: 步骤 5 中的图像 1,1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Speakers Replacement, Speakers: 步骤 6 中的图像 1,1
    • Use the spudger to pull the speaker wire plug from its socket.
  7. Toshiba Encore Mini Speakers Replacement: 步骤 7 中的图像 1,1
    • Carefully use the metal spudger to remove the speaker from the frame of the phone.
    • The speaker is attached with some double-sided adhesive and may be difficult to remove.
结论
Khaled Alsaghayer
于03/04/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S5-G5, Wilson Spring 2017 IUPUI, Team S5-G5, Wilson Spring 2017 的会员
IUPUI-WILSON-S17S5G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 150
