跳转到主内容
Toshiba Dynabook T552-58G Space Bar Replacement
  1. Toshiba Dynabook T552-58G Space Bar Replacement, Space Bar: 步骤 1 中的图像 1,1
    • The space bar is located on the bottom of the keyboard.
  2. Toshiba Dynabook T552-58G Space Bar Replacement: 步骤 2 中的图像 1,2 Toshiba Dynabook T552-58G Space Bar Replacement: 步骤 2 中的图像 2,2
    • Gently pry the broken space bar up with from the back with your finger.
  3. Toshiba Dynabook T552-58G Space Bar Replacement: 步骤 3 中的图像 1,1
    • You should now see the key retainer.
    • Do not remove anything else because this is crucial for replacing the key.
  4. Toshiba Dynabook T552-58G Space Bar Replacement: 步骤 4 中的图像 1,3 Toshiba Dynabook T552-58G Space Bar Replacement: 步骤 4 中的图像 2,3 Toshiba Dynabook T552-58G Space Bar Replacement: 步骤 4 中的图像 3,3
    • Gently lift up the bottom metal prongs.
    • Insert the two ends of the prong into the small metal loops located at the top of the key pad.
    • Gently press the key down until you hear a click.
终点
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 8
过去 30 天: 15
总计 477
