跳转到主内容
Toshiba Dynabook T552-58G Battery Replacement
  1. Toshiba Dynabook T552-58G Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the computer so that the back panel is facing you.
  2. Toshiba Dynabook T552-58G Battery Replacement: 步骤 2 中的图像 1,2 Toshiba Dynabook T552-58G Battery Replacement: 步骤 2 中的图像 2,2
    • Push the right battery cover lock (labeled as number 1) to the right.
    • It should now be on the unlock symbol.
  3. Toshiba Dynabook T552-58G Battery Replacement: 步骤 3 中的图像 1,1
    • Push and hold the left battery cover lock (labeled as number 2) to the left.
    • It should now be on the number 2.
  4. Toshiba Dynabook T552-58G Battery Replacement: 步骤 4 中的图像 1,2 Toshiba Dynabook T552-58G Battery Replacement: 步骤 4 中的图像 2,2
    • While holding the left battery cover lock, pull up on the indent found in the center of the battery pack.
    • Lift up on the battery pack to remove it from computer.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 19
总计 717
