跳转到主内容
Toshiba Dynabook AX 53D Memory Replacement
你所需要的
  1. Toshiba Dynabook AX 53D Memory Replacement, Battery: 步骤 1 中的图像 1,1
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Memory Replacement: 步骤 2 中的图像 1,1
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Memory Replacement, Memory: 步骤 3 中的图像 1,1
    • Remove the 4.5 mm screw labeled 4 and lift up panel from the vented 2" x "4 memory cover in the middle of the computer.
  4. Toshiba Dynabook AX 53D Memory Replacement: 步骤 4 中的图像 1,1
    • Gently pull apart the two metal support clips on either side of the chip to release from the socket. It will spring upwards when it is properly released.
  5. Toshiba Dynabook AX 53D Memory Replacement: 步骤 5 中的图像 1,1
    • Gently pull the chip out of the clips.
    • Touching the contacts or the chips on the board could destroy the components.
结论
另外一个人完成了本指南。
Christopher
于03/20/17注册
510 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 14
总计 335
