跳转到主内容
Toshiba Dynabook AX 53D Keyboard Replacement
你所需要的
  1. Toshiba Dynabook AX 53D Keyboard  Replacement, Battery: 步骤 1 中的图像 1,1
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Keyboard  Replacement: 步骤 2 中的图像 1,1
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Keyboard  Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Using the #J1 bit, remove the 17 recessed 7.3 mm B6 screws from the underside of laptop and the 3.1 mm #J0 F3 screw inside the battery compartment.
  4. Toshiba Dynabook AX 53D Keyboard  Replacement: 步骤 4 中的图像 1,2 Toshiba Dynabook AX 53D Keyboard  Replacement: 步骤 4 中的图像 2,2
    • Run the blue plastic opening tool underneath the media bezel and gently pry from the front panel.
  5. Toshiba Dynabook AX 53D Keyboard  Replacement: 步骤 5 中的图像 1,1
    • Using the #J0 bit, remove the two 3.1 mm screws securing the top of the keyboard.
  6. Toshiba Dynabook AX 53D Keyboard  Replacement: 步骤 6 中的图像 1,2 Toshiba Dynabook AX 53D Keyboard  Replacement: 步骤 6 中的图像 2,2
    • Pop out the black plastic tab on either side of the ribbon cable. Holding the cable on each side, detach from laptop.
结论
Christopher
于03/20/17注册
510 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 20
总计 1,039
