跳转到主内容
Toshiba Dynabook AX 53D Hard Drive Replacement
你所需要的
  1. Toshiba Dynabook AX 53D Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Hard Drive Replacement: 步骤 2 中的图像 1,1
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Start by using the #J1 screw bit to unscrew the the two 4.6 mm hard drive bay screws located on the underside of the laptop. They are located next to the Windows license sticker.
  4. Toshiba Dynabook AX 53D Hard Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Dynabook AX 53D Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Gently pull horizontally on the clear plastic tag to unplug the hard drive.
    • Make sure not to touch the circuit board or connectors on the drive as that may damage them.
  5. Toshiba Dynabook AX 53D Hard Drive Replacement: 步骤 5 中的图像 1,1
    • The drive can now be removed from the metal drive retainer by unscrewing the four exposed 4.1 mm #J1 screws on either side of the drive.
  6. Toshiba Dynabook AX 53D Hard Drive Replacement: 步骤 6 中的图像 1,1
    • The secondary hard drive can be removed following the same process on the right drive bay.
结论
Christopher
于03/20/17注册
510 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 28
总计 1,038
