跳转到主内容
Toshiba Chromebook CB35-A3120 Speakers Replacement
你所需要的
  1. Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: 步骤 1 中的图像 1,2 Toshiba Chromebook CB35-A3120 Speakers Replacement, Speakers: 步骤 1 中的图像 2,2
    • Using a Y1 screw driver head remove all ten .9mm screws from the back cover
    • Set the screws aside in preparation for reassembly
  2. Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 2 中的图像 1,2 Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 2 中的图像 2,2
    • Remove the back cover by placing a prying tool in the SD slot and popping the clips out of place.
  3. Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 3 中的图像 1,3 Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 3 中的图像 2,3 Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 3 中的图像 3,3
    • Unscrew the battery by using a J1 screw driver head, and place the four .7mm screws off to the side
    • Using a pry tool, pop the battery connector out of place and gently lift the battery upward.
  4. Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 4 中的图像 1,3 Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 4 中的图像 2,3 Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 4 中的图像 3,3
    • Remove the right side speaker by popping it out of place with your finger
    • Follow the speaker wire along the clips underneath the battery until you reach the left hand speaker
  5. Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 5 中的图像 1,2 Toshiba Chromebook CB35-A3120 Speakers Replacement: 步骤 5 中的图像 2,2
    • Unplug the connector wiring the speaker to the mother board.
    • Pop the speaker out of the computer, similar to the method used in the previous step.
结论
2等其他人完成本指南。
Jayce Houghton
于02/15/17注册
176 声望
撰写一个指南
团队
USF Tampa, Team 15-6, Remmell Spring 2017 USF Tampa, Team 15-6, Remmell Spring 2017 的会员
USFT-REMMELL-S17S15G6
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 749
