跳转到主内容
Toshiba Chromebook 2 Battery Replacement
你所需要的
  1. Toshiba Chromebook 2 Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Battery Replacement: 步骤 2 中的图像 1,1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Battery Replacement: 步骤 3 中的图像 1,2 Toshiba Chromebook 2 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Battery Replacement: 步骤 4 中的图像 1,2 Toshiba Chromebook 2 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the back panel by pulling up on 2 adjacent corners.
  6. Toshiba Chromebook 2 Battery Replacement, Battery: 步骤 6 中的图像 1,2 Toshiba Chromebook 2 Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the 4 Phillips 2 mm screws holding the battery in place with the Phillips #0 screwdriver.
  7. Toshiba Chromebook 2 Battery Replacement: 步骤 7 中的图像 1,2 Toshiba Chromebook 2 Battery Replacement: 步骤 7 中的图像 2,2
    • Press down on the white clip and softly pull the wires out of the port to disconnect battery from the motherboard.
  8. Toshiba Chromebook 2 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the battery by gently pulling up on the bottom corners.
结论
50等其他人完成本指南。
Foster Chaney
于10/08/15注册
762 声望
撰写一个指南
团队
IUPUI, Team 1-3, Hagerty Fall 2015 IUPUI, Team 1-3, Hagerty Fall 2015 的会员
IUPUI-HAGERTY-F15S1G3
5 名成员
创作了7篇指南
7条评论
does the cb30-b-103 battery also work with the cb30-b-104 series?
henrikahlberg94 - 回复
I had four screws holding down battery.
When re-installing cover, don’t get confused. There are two holes under rubber feet on side CLOSEST TO HINGES. These do not accept the two screws - put them on side AWAY FROM HINGES.
Bill Brasier - 回复
Good instructions, my chrome is back to normal again .
Alexander Slaven - 回复
Many thanks but now there’s no curser! What do I do?
Chris in UK
Chris Tighe - 回复
Thank you, easy to follow, works like a dream
steve smith - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 28,787
