跳转到主内容
Toshiba Chromebook 2 Back Cover Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Toshiba Chromebook 2 Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove all external devices from the Toshiba Chromebook 2.
  2. Toshiba Chromebook 2 Back Cover Replacement: 步骤 2 中的图像 1,1
    • Close the Toshiba Chromebook 2 and turn it over so that the bottom of the laptop is facing upwards toward you with the lettering on the bottom facing right side up.
  3. Toshiba Chromebook 2 Back Cover Replacement: 步骤 3 中的图像 1,2 Toshiba Chromebook 2 Back Cover Replacement: 步骤 3 中的图像 2,2
    • Remove the 8 visible Phillips 8.25 mm screws using the Phillips #0 screwdriver.
  4. Toshiba Chromebook 2 Back Cover Replacement: 步骤 4 中的图像 1,2 Toshiba Chromebook 2 Back Cover Replacement: 步骤 4 中的图像 2,2
    • Remove 2 hidden Phillips 8.25 mm screws located underneath the rubber grips at the back (opposite the hinges) with the Phillips #0 screwdriver.
    • The rubber grips are glued in place, so you'll need to peel them up with a spudger or other pry tool.
  5. Toshiba Chromebook 2 Back Cover Replacement: 步骤 5 中的图像 1,1
    • Remove the back panel by pulling up on 2 adjacent corners.
结论
团队
Cal Poly, Team 10-4, Livingston Fall 2016 Cal Poly, Team 10-4, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S10G4
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 88
