跳转到主内容
Toshiba Canvio Connect V73600-C Disassembly
你所需要的
  1. Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: 步骤 1 中的图像 1,2 Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: 步骤 1 中的图像 2,2
    • On the side of your hard drive casing, insert a spudger.
    • This can be tricky as the tolerances are quite tight.
    • I used a needle to make the gap big enough to insert a pick.
  2. Toshiba Canvio Connect V73600-C Disassembly, Continue opening: 步骤 2 中的图像 1,1
    • Slide your spudger along the gap in the casing you made in the previous step, continuing to open the device.
  3. Toshiba Canvio Connect V73600-C Disassembly, Keep going: 步骤 3 中的图像 1,1
    • Slide the spudger around the corner of the casing to start opening the next side.
    • There may be a gap big enough to see the plastic clips holding the device together.
  4. Toshiba Canvio Connect V73600-C Disassembly, Prise the casing open: 步骤 4 中的图像 1,1
    • Once there is a big enough gap in the casing, gently prise the two parts away from each other, being sure not to break any clips.
    • This will reveal the hard drive in the casing.
  5. Toshiba Canvio Connect V73600-C Disassembly, Extract the hard drive: 步骤 5 中的图像 1,1
    • Simply lift the drive out of the case.
    • There may be some friction due to the anti-shock rubber on the corners of the drive.
    • Gently pry with a plastic pry tool if required.
  6. Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: 步骤 6 中的图像 1,3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: 步骤 6 中的图像 2,3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: 步骤 6 中的图像 3,3
    • As the drive has a USB port soldered directly to its logic board, instead of a converter board in between, disassembling this device seems to be pointless unless the hard drive is being used for parts.
结论
2等其他人完成本指南。
CONVERSION
于03/07/20注册
1,279 声望
创作了8篇指南
团队
Australia Australia 的会员
Community
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 30
过去 30 天: 140
总计 5,034
