跳转到主内容
Toshiba CB35-C3300 Chromebook 2 SSD Replacement
你所需要的
  1. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: 步骤 1 中的图像 1,2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 步骤 2 中的图像 1,2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 步骤 2 中的图像 2,2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 步骤 3 中的图像 1,1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 步骤 4 中的图像 1,2 Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 步骤 4 中的图像 2,2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 SSD Replacement, SSD: 步骤 5 中的图像 1,1
    • Remove the translucent yellow tape that connects the Wi-Fi card and the SSD.
    • Using a Phillips #1 screwdriver, remove the single screw connecting the SSD to the motherboard.
  6. Toshiba CB35-C3300 Chromebook 2 SSD Replacement: 步骤 6 中的图像 1,1
    • Gently grab the SSD and remove the card from the SSD slot on the motherboard, careful not to damage any of the connections on the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 18
总计 399
