跳转到主内容
Toshiba CB35-C3300 Chromebook 2 Battery Replacement
你所需要的
  1. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: 步骤 1 中的图像 1,2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
  2. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 2 中的图像 1,2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 2 中的图像 2,2
    • Remove the 10 7.1 mm screws using Phillips #1 screwdriver.
  3. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 3 中的图像 1,1
    • Loosen the back cover by using a plastic opening tool all the way around the device.
    • There are areas all along the sides of the device that help aid in this.
    • Be careful when prying, and go slow. The silver plastic frame around the dull gray plastic bottom is fragile and easily dented from prying pressure.
  4. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 4 中的图像 1,2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 4 中的图像 2,2
    • Remove the back cover by gently lifting up on one side of the device.
    • The easiest side to lift up on is the one with the removed rubber foot pads.
  5. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: 步骤 5 中的图像 1,2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
  6. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 6 中的图像 1,2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 6 中的图像 2,2
    • Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
  7. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 7 中的图像 1,3 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 7 中的图像 2,3 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 7 中的图像 3,3
    • To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
    • Gently shaking the wire from left to right helps with the wire removal
  8. Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 8 中的图像 1,2 Toshiba CB35-C3300 Chromebook 2 Battery  Replacement: 步骤 8 中的图像 2,2
    • Remove the battery by gently pulling on the bottom corners.
    • Be careful to move the battery's wire under the speaker's wire.
结论
另外一个人完成了本指南。
varun kapadia
于10/18/17注册
219 声望
撰写一个指南
团队
USF Tampa, Team S1-G121, Cagle Fall 2017 USF Tampa, Team S1-G121, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G121
3 名成员
创作了14篇指南
一条评论
Thanks again IFIXIT!!! Repaced battery on Toshiba C35 C3300 with your HELP. Guy Rogers
Guy Rogers - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 1,218
