跳转到主内容
Toshiba A1304T Mini LCD Screen Replacement
你所需要的
  1. Toshiba A1304T Mini LCD Screen Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Toshiba A1304T Mini LCD Screen Replacement: 步骤 2 中的图像 1,2 Toshiba A1304T Mini LCD Screen Replacement: 步骤 2 中的图像 2,2
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Mini LCD Screen Replacement: 步骤 3 中的图像 1,2 Toshiba A1304T Mini LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
  4. Toshiba A1304T Mini LCD Screen Replacement, Mini LCD Screen: 步骤 4 中的图像 1,2 Toshiba A1304T Mini LCD Screen Replacement, Mini LCD Screen: 步骤 4 中的图像 2,2
    • Using a small Phillips screwdriver, gently pry off the LCD screen from the board.
  5. Toshiba A1304T Mini LCD Screen Replacement: 步骤 5 中的图像 1,2 Toshiba A1304T Mini LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Using the head of the screwdriver, flip up the black tab connecting the ribbon-wire.
    • Gently pull the LCD screen away from the board, the cable should come off with nearly no resistance.
结论
另外一个人完成了本指南。
Christopher
于04/22/10注册
90 声望
创作了8篇指南
团队
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G6
4 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 2,993
