跳转到主内容
配件
没有特定配件。
  1. Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
    Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
  4. If needed, use the flathead screwdriver to gently pry the panel from the phone. Using your fingers, lift the panel from the device.
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  5. Use your fingers to gently detach the ribbon wire from the logic board. Use your fingers to gently detach the ribbon wire from the logic board. Use your fingers to gently detach the ribbon wire from the logic board.
    • Use your fingers to gently detach the ribbon wire from the logic board.
  6. Use the flathead screwdriver to pry the logic board and keypad from the device. Use the flathead screwdriver to pry the logic board and keypad from the device.
    • Use the flathead screwdriver to pry the logic board and keypad from the device.
  7. Use your thumb to peel the keypad from the device. Use your thumb to peel the keypad from the device.
    • Use your thumb to peel the keypad from the device.
结论
Christopher
于2010年04月22日注册
90 信誉积分
创作了8篇指南
团队
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G6
4 名成员
创作了16篇指南
添加评论
浏览统计数据:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
总计 2,513
