跳转到主内容
Toshiba A1304T Keypad Replacement
你所需要的
  1. Toshiba A1304T Keypad Replacement, Back panel: 步骤 1 中的图像 1,1
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Keypad Replacement: 步骤 2 中的图像 1,1
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Keypad Replacement: 步骤 3 中的图像 1,2 Toshiba A1304T Keypad Replacement: 步骤 3 中的图像 2,2
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Keypad Replacement, Keypad: 步骤 4 中的图像 1,3 Toshiba A1304T Keypad Replacement, Keypad: 步骤 4 中的图像 2,3 Toshiba A1304T Keypad Replacement, Keypad: 步骤 4 中的图像 3,3
    • Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
  5. Toshiba A1304T Keypad Replacement: 步骤 5 中的图像 1,2 Toshiba A1304T Keypad Replacement: 步骤 5 中的图像 2,2
    • Use a flathead screwdriver to gently pry the logic board and keypad from the device.
  6. Toshiba A1304T Keypad Replacement: 步骤 6 中的图像 1,2 Toshiba A1304T Keypad Replacement: 步骤 6 中的图像 2,2
    • Peel the keypad from the logic board using your thumb.
结论
Christopher
于04/22/10注册
90 声望
创作了8篇指南
团队
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G6
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,663
