本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace the Toshiba A1304T camera.
你所需要的
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
Using a small Phillips screwdriver, remove the two black screws from the positions indicated.
Gently pull the silver plate from the phone using your fingers.
即将完成!
结论
