跳转到主内容
Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement
你所需要的
  1. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: 步骤 1 中的图像 1,2 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Casing: 步骤 1 中的图像 2,2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 步骤 2 中的图像 1,1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing Screws: 步骤 3 中的图像 1,1
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Removing the Wheel: 步骤 4 中的图像 1,1
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement, Rear Wheel Suspension: 步骤 5 中的图像 1,1
    • After removing the rear wheels, remove the 8mm screw under each spring with a Phillips 1 screwdriver.
  6. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 步骤 6 中的图像 1,1
    • Slide off the bottom part of the rod connected to the chassis.
  7. Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 步骤 7 中的图像 1,3 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 步骤 7 中的图像 2,3 Torque King Electric RTR RC Monster Truck Rear Wheel Suspension Replacement: 步骤 7 中的图像 3,3
    • Pull the black washer inside the spring downwards and towards the truck's rear simultaneously in order to remove the suspension.
结论
另外一个人完成了本指南。
Colton Sholtis
于01/30/15注册
257 声望
创作了2篇指南
团队
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G30
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 197
