跳转到主内容
Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement
你所需要的
  1. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: 步骤 1 中的图像 1,2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Casing: 步骤 1 中的图像 2,2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: 步骤 2 中的图像 1,1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing Screws: 步骤 3 中的图像 1,1
    • Using a Phillips 1 screwdriver, completely unscrew the 8mm screw located in the center of the wheel. Repeat this step for other wheels if needed.
  4. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Removing the Wheel: 步骤 4 中的图像 1,1
    • Carefully pull the wheel off of its axle. Repeat for other wheels as necessary.
  5. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: 步骤 5 中的图像 1,2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement, Front Wheel Suspension: 步骤 5 中的图像 2,2
    • Pull the top half of the suspension to unclip it.
  6. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: 步骤 6 中的图像 1,1
    • Remove the top clip along with the spring.
  7. Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: 步骤 7 中的图像 1,2 Torque King Electric RTR RC Monster Truck Front Wheel Suspension Replacement: 步骤 7 中的图像 2,2
    • Pull up the bottom half of the suspension to unclip it.
结论
团队
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G30
4 名成员
创作了16篇指南
一条评论
Hola buenas noches, me pueden hacer el favor de ayudarme a armar de nuevo la parte de la suspensión de la parte delantera, te go todas las piezas pero no recuerdo como van
Vivian giseli Barrero - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 288
