跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide requires a Phillips #00 screwdriver.
配件
没有特定配件。
  1. Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
    • Beginning at the bottom of the truck, twist the release clip on the casing until the release clip is no longer covering the battery casing.
  2. Next, use a Phillips 00 screwdriver to remove the 8mm screw on the battery casing and remove the battery casing.
    • Next, use a Phillips 00 screwdriver to remove the 8mm screw on the battery casing and remove the battery casing.
  3. Do not skip this step if you are continuing onto the next step, you will risk electric shock.
    • Do not skip this step if you are continuing onto the next step, you will risk electric shock.
    • Finally, remove the battery from the white connector by squeezing the clip on the connector while pulling.
结论
Thomas White
于2015年02月02日注册
243 信誉积分
创作了2篇指南
团队
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G30
4 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 8
总计 258
