跳转到主内容
Torque King Electric RTR RC Monster Truck Antenna Replacement
你所需要的
  1. Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: 步骤 1 中的图像 1,2 Torque King Electric RTR RC Monster Truck Antenna Replacement, Casing: 步骤 1 中的图像 2,2
    • From the top view, remove each of the four pins that hold the casing in place.
  2. Torque King Electric RTR RC Monster Truck Antenna Replacement: 步骤 2 中的图像 1,1
    • Slowly pull the casing up to remove it.
  3. Torque King Electric RTR RC Monster Truck Antenna Replacement, Loosen Screw: 步骤 3 中的图像 1,1
    • Loosen the 10mm screw surrounded by the copper using a #2 Phillips head screwdriver.
    • The wire that connects the antenna to the circuitry of the truck might be blocking the screw. Take care when moving the wire out of the way not to pull it from its soldering.
  4. Torque King Electric RTR RC Monster Truck Antenna Replacement, Remove Antenna: 步骤 4 中的图像 1,1
    • Carefully slide the antenna out from under the screw and remove.
结论
另外一个人完成了本指南。
Colton Sholtis
于01/30/15注册
257 声望
创作了2篇指南
团队
Cal Poly, Team 6-30, Amido Winter 2015 Cal Poly, Team 6-30, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G30
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 490
