跳转到主内容
Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement
你所需要的
  1. Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Disconnect the spark plug wire: 步骤 1 中的图像 1,2 Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Disconnect the spark plug wire: 步骤 1 中的图像 2,2
    • Before you begin, ensure that the mower is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Chock the rear wheels: 步骤 2 中的图像 1,1
    • Chock the rear wheels to prevent the mower from rolling during service.
    • If the blades are extremely dirty, you can clean them using the washout fitting so the bolts on the underside of the blade guard are accessible.
  3. Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Lift up the deflector: 步骤 3 中的图像 1,2 Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Lift up the deflector: 步骤 3 中的图像 2,2
    • Lift up the plastic deflector.
  4. Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Remove the grass bag: 步骤 4 中的图像 1,3 Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Remove the grass bag: 步骤 4 中的图像 2,3 Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Remove the grass bag: 步骤 4 中的图像 3,3
    • While holding the deflector up and out of the way, lift the grass bag handle away from the mower to detach it.
    • Remove the grass bag.
  5. Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Tilt the mower on its side: 步骤 5 中的图像 1,1
    • Tilt the mower onto its side so the blades are facing out.
    • This may require two people.
  6. Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Remove the blade bolt: 步骤 6 中的图像 1,2 Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Remove the blade bolt: 步骤 6 中的图像 2,2
    • Use an impact driver with a 5/8-inch socket to remove the right blade bolt.
    • If necessary, brace the blade with a screwdriver or extension by placing it in the hole in the metal blade guard.
  7. Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Remove the blade: 步骤 7 中的图像 1,2 Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Remove the blade: 步骤 7 中的图像 2,2
  8. Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Remove the blade key adapter: 步骤 8 中的图像 1,2 Toro Walk Behind Mowers 21199HD 2018 Right Blade Replacement, Remove the blade key adapter: 步骤 8 中的图像 2,2
    • Remove the right blade key adapter.
结论
Carsten Frauenheim
于03/10/20注册
118,976 声望
创作了341篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,077篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 24
总计 315
