简介
Replacing the cutting blade on a lawn mower is important to ensure that your grass is cut correctly and that your lawn mower is running efficiently. This is a simple fix that requires little to no expertise or previous experience. Just make sure to be careful when handling the blade itself and all should run smoothly.
你所需要的
Disconnect the spark plug to ensure that the lawn mower does not accidentally turn over and cause the mower to turn on.
This simple fix should help make the lawn mower function efficiently and safely for years to come.
3等其他人完成本指南。
