跳转到主内容
加入维修社区 - 创建账户
Torn-Off Backpack Shoulder Strap Repair
你所需要的
  1. Torn-Off Backpack Shoulder Strap Repair, Torn-Off Backpack Shoulder Strap Repair: 步骤 1 中的图像 1,1
    • Thread the needle with the 0.7 yards of upholstery nylon thread.
  2. Torn-Off Backpack Shoulder Strap Repair: 步骤 2 中的图像 1,3 Torn-Off Backpack Shoulder Strap Repair: 步骤 2 中的图像 2,3 Torn-Off Backpack Shoulder Strap Repair: 步骤 2 中的图像 3,3
    • Align the two ends of the thread, and tie a knot.
    • Trim the extra thread off.
  3. Torn-Off Backpack Shoulder Strap Repair: 步骤 3 中的图像 1,2 Torn-Off Backpack Shoulder Strap Repair: 步骤 3 中的图像 2,2
    • Trim the frayed edges and thread off of the backpack and shoulder strap.
  4. Torn-Off Backpack Shoulder Strap Repair: 步骤 4 中的图像 1,2 Torn-Off Backpack Shoulder Strap Repair: 步骤 4 中的图像 2,2
    • Align the 2x5 nylon cloth with the torn off backpack strap.
    • Make sure that the nylon cloth is able to fold over the strap, and align up with the other end.
  5. Torn-Off Backpack Shoulder Strap Repair: 步骤 5 中的图像 1,2 Torn-Off Backpack Shoulder Strap Repair: 步骤 5 中的图像 2,2
    • Begin sewing across the handle with the backstitching sewing technique.
    • Make sure that the stitch goes all the way through the Nylon as you sew.
    • The second picture of this step did not satisfy the second part of this step.
  6. Torn-Off Backpack Shoulder Strap Repair: 步骤 6 中的图像 1,3 Torn-Off Backpack Shoulder Strap Repair: 步骤 6 中的图像 2,3 Torn-Off Backpack Shoulder Strap Repair: 步骤 6 中的图像 3,3
    • To end the stitch, push the needle about halfway through.
    • Take the thread, and wrap it around the sharp side of the needle.
    • Pull the needle all the way through.
    • If the stitch did not go through both sides of the nylon, repeat steps 5 and 6 over on the other side. Remember to replace the thread by repeating steps 1 and 2.
    • If you want extra support, repeat steps 5 and 6 on the other side. Remember to replace the thread by repeating steps 1 and 2.
  7. Torn-Off Backpack Shoulder Strap Repair: 步骤 7 中的图像 1,1
    • Cut the thread, and remove the thread from the needle.
    • Repeat steps 1 and 2 with the 1 meter long thread.
  8. Torn-Off Backpack Shoulder Strap Repair: 步骤 8 中的图像 1,3 Torn-Off Backpack Shoulder Strap Repair: 步骤 8 中的图像 2,3 Torn-Off Backpack Shoulder Strap Repair: 步骤 8 中的图像 3,3
    • Align the handle with the shoulder of the backpack.
    • Secure the handle in place by applying pressure, and then begin sewing with the backstitching sewing technique.
    • When sewing, make sure to follow your thread and needle carefully. A misguided needle will lead to unwanted tangles.
    • End the stitch by repeating step 6.
  9. Torn-Off Backpack Shoulder Strap Repair: 步骤 9 中的图像 1,1
    • Trim off any frayed edges or loose string.
结论
After preceding through all the steps, you should now have a durable, functional backpack! If parts of the strap begin ripping, you can repair the tear by applying the backstitching sewing technique anywhere!
15等其他人完成本指南。
Emily
于04/07/15注册
634 声望
撰写一个指南
团队
Cal Poly, Team 28-1, Green Spring 2015 Cal Poly, Team 28-1, Green Spring 2015 的会员
CPSU-GREEN-S15S28G1
4 名成员
创作了9篇指南
2指南评论
Emily your tutorial is great the photos are great
thank you. . . !
I know how much work goes into making a tutorial like this
nazo - 回复
Outstanding instructional! Thank you tho for hands down the best tutorial ive come across all day! TY for not starting off with 2 pages of your life story in the beginning too for real. great job with the instructions- easy to follow and to the point. I loved that there were a few pics in each step that if you glided over one of the images, it would highlight and enlarge as the main photo/step. extremely helpful and easy to guide through:) Also, can i just cut a small slice the size of strap through the bag at top and stick the strap end in and hand sew ? or do i have to have another piece of fabric sewn onto the strap to be able to do that....? i am trying to make it look like the strap never broke/was not repaired ya know? Than'Q!
Brit Leaf - 回复
添加评论
浏览统计数据:
过去 24 小时: 23
过去 7 天: 182
过去 30 天: 692
总计 174,620
