本指南有最近更改,您可查看未经巡查的最新版本。
简介
Using a metal spudger may cause damage but it is the most efficient tool to use. There is a sticky adhesive under the top button compartment followed by a metal piece then a rubber piece. Once you get the first part off the rest is simple.
你所需要的
Insert the flat end of wide metal spudger into the seam of the plastic buffer surrounding the buttons and pry it open.
即将完成!
结论
