跳转到主内容
加入维修社区 - 创建账户
Top Cover Removal
你所需要的
  1. Top Cover Removal, Remove film door: 步骤 1 中的图像 1,1
    • Push down the latch to release the film door.
  2. Top Cover Removal, Remove top cover screws: 步骤 2 中的图像 1,3 Top Cover Removal, Remove top cover screws: 步骤 2 中的图像 2,3 Top Cover Removal, Remove top cover screws: 步骤 2 中的图像 3,3
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
  3. Top Cover Removal, Remove top cover screws: 步骤 3 中的图像 1,3 Top Cover Removal, Remove top cover screws: 步骤 3 中的图像 2,3 Top Cover Removal, Remove top cover screws: 步骤 3 中的图像 3,3
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
  4. Top Cover Removal, Lift top cover: 步骤 4 中的图像 1,1
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
  5. Top Cover Removal, Access flash connections: 步骤 5 中的图像 1,2 Top Cover Removal, Access flash connections: 步骤 5 中的图像 2,2
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
  6. Top Cover Removal, Discharge flash capacitors: 步骤 6 中的图像 1,1
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  7. Top Cover Removal, Disconnect right flex cable: 步骤 7 中的图像 1,1
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
  8. Top Cover Removal, Disconnect left flex cable: 步骤 8 中的图像 1,1
    • Desolder the red wire.
  9. Top Cover Removal, Desolder flash connections: 步骤 9 中的图像 1,2 Top Cover Removal, Desolder flash connections: 步骤 9 中的图像 2,2
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
  10. Top Cover Removal, Desolder the flash flex cable: 步骤 10 中的图像 1,2 Top Cover Removal, Desolder the flash flex cable: 步骤 10 中的图像 2,2
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
结论
Sam Gustafson
于09/01/22注册
10,623 声望
创作了57篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 26
总计 400
