跳转到主内容
Tommy Hilfiger Quartz Watch Band Link Replacement
你所需要的
  1. Tommy Hilfiger Quartz Watch Band Link Replacement, Band Link: 步骤 1 中的图像 1,1
    • Place the watch on your wrist and approximate the number of links to be removed.
  2. Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 2 中的图像 1,1
    • Identify the arrows located directly on the links and point them downwards in the south position.
  3. Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 3 中的图像 1,3 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 3 中的图像 2,3 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 3 中的图像 3,3
    • Lay and secure the wristband on the watchband holder.
  4. Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 4 中的图像 1,3 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 4 中的图像 2,3 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 4 中的图像 3,3
    • Align the tip of the pin pusher on the pin.
    • Begin tapping the hammer with force to push the link pin out.
  5. Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 5 中的图像 1,2 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 5 中的图像 2,2
    • Set aside the link pins and links that have been removed from the watch.
  6. Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 6 中的图像 1,3 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 6 中的图像 2,3 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 6 中的图像 3,3
    • In order to add links to the wristband, ensure that the arrows are pointing upwards in the north position.
    • Secure the wristband on the watchband holder.
  7. Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 7 中的图像 1,2 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 7 中的图像 2,2
    • Align the link pins to be added on the holes that connect the desired link to the wristband.
  8. Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 8 中的图像 1,3 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 8 中的图像 2,3 Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 8 中的图像 3,3
    • Use the hammer to gently tap the link pins into the holes until the pin is completely resting in position.
  9. Tommy Hilfiger Quartz Watch Band Link Replacement: 步骤 9 中的图像 1,1
    • Finally, place the watch on your wrist to determine if the links are secure and the fitment is comfortable.
    • If adjustments need to be made, refer to step 2 for the subtraction of links and step 6 for the addition of links.
终点
Ayush Theyyil
于09/14/21注册
169 声望
撰写一个指南
团队
York University, Team F-3, Woodhouse Fall 2021 York University, Team F-3, Woodhouse Fall 2021 的会员
YORK-WOODHOUSE-F21SFG3
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 28
过去 30 天: 102
总计 6,263
