跳转到主内容
TomTom XXL 540 Battery Replacement
你所需要的
  1. TomTom XXL 540 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Peel back the sticker on the bottom of the device to reveal the two screws.
  2. TomTom XXL 540 Battery Replacement: 步骤 2 中的图像 1,1
    • Unscrew the two T5 Torx screws.
  3. TomTom XXL 540 Battery Replacement: 步骤 3 中的图像 1,1
    • Wedge the flat head of the screwdriver into the edge of the device. Gently lift the screen from the cover.
  4. TomTom XXL 540 Battery Replacement: 步骤 4 中的图像 1,1
    • Release the yellow ribbon cable.
  5. TomTom XXL 540 Battery Replacement: 步骤 5 中的图像 1,1
    • Identify the green motherboard. Unscrew the three screws holding the board in place.
  6. TomTom XXL 540 Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the motherboard from the back plate.
  7. TomTom XXL 540 Battery Replacement: 步骤 7 中的图像 1,1
    • Unplug the battery from the board.
  8. TomTom XXL 540 Battery Replacement: 步骤 8 中的图像 1,1
    • Plug the new battery into the white receptacle on the green motherboard.
  9. TomTom XXL 540 Battery Replacement: 步骤 9 中的图像 1,1
    • Transfer the green motherboard back into the back plate and secure it with the 3 screws.
  10. TomTom XXL 540 Battery Replacement: 步骤 10 中的图像 1,1
    • Reconnect the yellow ribbon cable and connect the screen and back plate back together.
  11. TomTom XXL 540 Battery Replacement: 步骤 11 中的图像 1,1
    • Insert the t-5 screws and tighten to secure.
  12. TomTom XXL 540 Battery Replacement: 步骤 12 中的图像 1,1
    • Replace the label to cover the screws.
结论
5等其他人完成本指南。
Mike Sollars
于07/11/13注册
519 声望
创作了3篇指南
团队
WRI115, Team 1-1, Ruszkiewicz Spring 2013 WRI115, Team 1-1, Ruszkiewicz Spring 2013 的会员
WRI115-RUSZKIEWICZ-S13S1G1
4 名成员
创作了6篇指南
一条评论
Very similar for the 4FL60 and 6000, except in :
Step 1 the screws are visible without removing any stickers
Step 4 hint: to release the ribbon, each end of the white bar has a self-sprung clip to ease away, try not to break them. And for the models above there is a small cable plug to unclip
Step 5 there are 5 screws holding the motherboard
Step 6 it is necessary to unclip plugs for the battery and speaker leads
and vice versa for reassembly
Jim Shaw - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 4,582
