当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Peel back the sticker, using the tweezers on the bottom of the device to reveal the two screws.
Unscrew the two T5 screws using the T5 Torx Screwdriver.
Insert the flat head screwdriver into the edge of the device. Using it as a lever, carefully pry the face-plate up.
Carefully grab the ribbon cable with two fingers and pull the yellow ribbon cable upwards away from the motherboard.
Remove the screen from of the face-plate.
Insert the new screen into the face-plate.
Reattach the yellow ribbon cable to the motherboard.
Using two hands, hold both ends of the device and snap the two plates together.
Re-insert the two T5 screws and tighten.
Re-apply the label edges back down to cover the screws.
取消:我没有完成这个指南。
3等其他人完成本指南。
与7其他贡献者
于07/11/13注册
519 声望
创作了3篇指南
徽章: 8
+ 5更多徽章
WRI115-RUSZKIEWICZ-S13S1G1
4 名成员
创作了6篇指南
Hi! Thanks for doing this. How do I release the yellow cable from the board?
Shaun B - 2016年11月9日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 19
总计 1,890
