跳转到主内容
TomTom XL Screen and Motherboard Replacement
你所需要的
  1. TomTom XL Screen and Motherboard Replacement, Screen and Motherboard: 步骤 1 中的图像 1,1
    • Slip a small plastic opening tool underneath the screen bezel, gently sliding it around the inside edge.
    • Starting at the corners, carefully pry up the screen bezel.
  2. TomTom XL Screen and Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the four Phillips #00 screws around the edge of the screen.
  3. TomTom XL Screen and Motherboard Replacement: 步骤 3 中的图像 1,3 TomTom XL Screen and Motherboard Replacement: 步骤 3 中的图像 2,3 TomTom XL Screen and Motherboard Replacement: 步骤 3 中的图像 3,3
    • Slide a small plastic opening tool under the top portion of the metal frame and gently lift it up.
    • Slide the plastic opening tool around the inner edge of the metal frame until it feels loose.
    • It may take some time to release the frame from the housing. Some force may be necessary—but be careful not to bend the frame's fragile interior bracket.
    • Remove the frame from the housing.
  4. TomTom XL Screen and Motherboard Replacement: 步骤 4 中的图像 1,2 TomTom XL Screen and Motherboard Replacement: 步骤 4 中的图像 2,2
    • Lifting from the upper edge of the screen, tilt the screen away from the device.
    • Tilt the screen slowly. Flipping the screen up too quickly may damage the display cable.
  5. TomTom XL Screen and Motherboard Replacement: 步骤 5 中的图像 1,2 TomTom XL Screen and Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the three Phillips #00 screws connecting the motherboard to the plastic housing:
    • Two Phillips #00 screws are located at the bottom of the first picture.
    • The third screw is hidden under the orange ribbon cable, near the screen.
    • You may have to carefully lift the screen in order to reach this screw.
  6. TomTom XL Screen and Motherboard Replacement: 步骤 6 中的图像 1,2 TomTom XL Screen and Motherboard Replacement: 步骤 6 中的图像 2,2
    • Flip the screen and motherboard over.
    • Gripping the plastic casing, disconnect the battery cable connector from the motherboard.
    • Disconnect the speaker cable connector from the motherboard.
    • Remove the motherboard and screen from the housing.
结论
另外一个人完成了本指南。
Adam Johnson
于04/21/10注册
122 声望
创作了2篇指南
团队
Cal Poly, Team 33-84, Johann Spring 2010 Cal Poly, Team 33-84, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G84
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 9,045
