跳转到主内容
TomTom VIA 1605TM Motherboard Replacement
你所需要的
  1. TomTom VIA 1605TM Motherboard  Replacement, Front Screen: 步骤 1 中的图像 1,3 TomTom VIA 1605TM Motherboard  Replacement, Front Screen: 步骤 1 中的图像 2,3 TomTom VIA 1605TM Motherboard  Replacement, Front Screen: 步骤 1 中的图像 3,3
    • Locate the round suction cup on the back of the device.
    • Twist the suction cup clockwise or counterclockwise while pulling back away from the device closer to your body until removed.
    • When reassembling twist the suction cup but, push in as oppose to pulling out.
  2. TomTom VIA 1605TM Motherboard  Replacement: 步骤 2 中的图像 1,1
    • Location of screw is where the suction cup was.
    • Insert 8mm Hex #T6 screw driver into screw.
    • Unscrew in counter clockwise direction.
    • When reassembling screw in the clockwise direction.
  3. TomTom VIA 1605TM Motherboard  Replacement: 步骤 3 中的图像 1,2 TomTom VIA 1605TM Motherboard  Replacement: 步骤 3 中的图像 2,2
    • Pry along the edges with the plastic opening tool to separate the back and front panel.
    • Try not to tear the screen open as you may break the part. Go about this gently but with enough force to remove the screen.
  4. TomTom VIA 1605TM Motherboard  Replacement: 步骤 4 中的图像 1,3 TomTom VIA 1605TM Motherboard  Replacement: 步骤 4 中的图像 2,3 TomTom VIA 1605TM Motherboard  Replacement: 步骤 4 中的图像 3,3
    • Place the new front panel (with new screen) on to the back panel. Press firmly along the edges to attach.
    • Only do this step of placing the front panel on if you are completed. If there are still components needed replacing postpone this step until the end.
  5. TomTom VIA 1605TM Motherboard  Replacement, Motherboard: 步骤 5 中的图像 1,3 TomTom VIA 1605TM Motherboard  Replacement, Motherboard: 步骤 5 中的图像 2,3 TomTom VIA 1605TM Motherboard  Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Keep the TOMTOM oriented so the curve is on the bottom. Locate the four 1mm Philips #J1 head screws attached to the motherboard.
    • Unscrew each of these in a counter clockwise direction.
    • When reassembling screw back in a clockwise direction.
    • The second picture is to represent where the four screws are located. The LCD screen does not disconnect from the motherboard until the next step.
  6. TomTom VIA 1605TM Motherboard  Replacement: 步骤 6 中的图像 1,3 TomTom VIA 1605TM Motherboard  Replacement: 步骤 6 中的图像 2,3 TomTom VIA 1605TM Motherboard  Replacement: 步骤 6 中的图像 3,3
    • Remove the Blue Ribbon Cable by pushing each side of the plastic holder with the nylon spudger.
    • This will remove the LCD screen from the motherboard.
  7. TomTom VIA 1605TM Motherboard  Replacement: 步骤 7 中的图像 1,1
    • Unplug the wire connecting to the speaker by pinching the sides connected to the back screen.
    • Pull back away (in the opposite direction) from the connector.
    • When reassembling push back into connector. Do not need to pinch anything. The "click" sound ensures solid connection.
  8. TomTom VIA 1605TM Motherboard  Replacement: 步骤 8 中的图像 1,2 TomTom VIA 1605TM Motherboard  Replacement: 步骤 8 中的图像 2,2
    • Unplug the battery, the same way we unplugged the speaker by pinching the sides of the connection.
    • Pull away from the connector
  9. TomTom VIA 1605TM Motherboard  Replacement: 步骤 9 中的图像 1,1
    • Properly dispose of the old motherboard. Replace with the new motherboard.
    • Skip this step(i.e. do not dispose of motherboard) if this part of prerequisite guide for the back cover replacement.
结论
2等其他人完成本指南。
Tyler Wade
于10/15/15注册
362 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-4, Catania Fall 2015 UMass Dartmouth, Team 4-4, Catania Fall 2015 的会员
UMASSD-CATANIA-F15S4G4
4 名成员
创作了5篇指南
一条评论
Trying to figure out y my gps is changing screen manual even i don't touch screen
Joseph Fixler - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 741
